Maybe I Can Afford A Turbo Kit But....
Discussion in 'Engine Building' started by silver_vti, Feb 18, 2003.
  1. silver_vti
    silver_vti Junior Member
    hi again. i was wondering:
    if i own a civic B16a2 stock...
    and i buy a turbo kit (lets say a modest one gaining 75-80hp).
    is that all my cost? (assuming obviously the 400 bucks of installation)
    what mods are recommended to go before and after the turbo?
    will i blow my engine to pieces easily?
    what psi is recommended for stock motor + turbo?
    is the vortech supercharger w/intercooler a good buy?
    i dont buy the fact that it's a 117whp bolt-on stock....
    is it???
    i need the best advice i can get cause i incurr in big buck costs of shipping and taxes if i have these items sent to perú (to be exact i spend around 43% more than anyone in the states)
    tks a lot for your help!
    ps. know little??? ask a lot. it helps.
  2. pissedoffsol
    if you simply slap on a turbo kit, chances are good that you will blow up. Maybe not now, maybe not in a year- but some day, it will happen.
    you need to get it tuned. do you have access to a dyno in peru? preferabbly one with a wideband o2 sensor.
    if you don't, i would highly suggest avoiding the turbo honda.
  3. silver_vti
    tks a lot for your answer.
    yes, i do have acces to the dyno.
    then, what are the necessary mods for a turbo?
    or the vortech issue?
    tks
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    re-work the bottom end of the B16, i.e. new pistons, and rods. Make your block is strong for the turbo, but that is for a lot of boost. It is best to just take precsutious measures to make sure that your engine last a little while. I think greddy makes a kit that will work on a stock block.
  5. pissedoffsol
    naw- he just wants a small kit for 70-80 horse. no point in doing the bottom end.
    What i recommend: piece together a kit from http://www.KS-motorsports.com and GET the hondata option.
    talk to them and make sure they give you a proper base map.
    from there- you are going to have to tune this yourself, unless there are hondata tuners in peru (doubtful - there isn't one in every state yet) but with a good base map, and an experienced dyno guy, you should be able to target your air/fuel ratios pretty good.
  6. silver_vti
    thanks pissed,
    i contacted the website and they've offered a max-rev turbo kit for 2,400. should i go for it?
    how's max-rev rated in the US market?
  7. pissedoffsol
    max rev is good shit. they were a supra store, but Geoff who used to work for z10 worked with them and made the honda kits. their manifolds fit well, and the turbo pieces are good. its a MUCH higher quality kit than the Drag 3 or rev hard if you ask me.
