MC swap w/o brake swap?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by xj0hnx, Jun 15, 2005.
  1. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I know I just recently read somewhere about this, but don't think it was here. Anyway, I scored an uber cheap15/16's from a 91 EX today, so I was thinking about putting it on.
    Has anyone here swapped a bigger MC onto stock set up, and if so, what were the results? I will be getting either GSRs when I get back, or VTi's while I am here, but I would just rather get parts on, or gone before I depart Germany.
  2. pissedoffsol
    put it on. the only thing it will do will give you less pedal travel per bite. it sends more fluid out. the 91 ex master is a nice cheap easy mod. autozone sells remnu's for like 50 bucks + core.
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    yeah, it will feel like it bites harder due to less pedal travel like B said. I'm upgrading as soon as i get my stainless lines and my rear disc
  4. xj0hnx
    C.C.TX.
    $50? Ouch, got mine for $15 :)
    So, no worries about locking up, just a tighter pedal feel?
  5. pissedoffsol
    some of us don't have access to edm junkyards... plus, mine is new/rebuilt :p
  6. xj0hnx
    C.C.TX.
    Yea, for a part that old, normally I would go with a rebuilt one, but this is way clean, and the fluid residue in the resevoir was nice and clean, not built up shit or particles, so I think it is in real good shape. Only thing is one of the fittings is stuck, so I gotta get it on a vise so I can get it out.
  7. bcman
    bcman Senior Member
    Davis, CA
    you'll have less pedal travel, but will require more pedal force. it's like having a shorter lever arm.
  8. phunky.buddha
    Dallas / Fort Worth, TX
    :thumbsup:
    Only $50 plus core from AutoZone? I have an extra one lying around... could just go get the 15/16 and drop it into Katie's car.
  9. 97CTR
    97CTR Senior Member
    I have a ctr mc lying around that I got with my swap, anyone know if that has more displacemant than the ex mc........sorry threadjack
  10. GSRCRXsi
    MD
    mine was 75 plus a 57 core at autozone. and i dont even know if im gonna ge thte right one.
    i went to pep boys first. and got one, but it was the wrong bolt pattern. then i got one that was the right bolt pattern but the wrong size (13/16). then he looked in the computer and found the right one, the 15/16 one, but there warehouse didnt stock it so he couldnt order it.
    off to advance. they dont even carry the 15/16 one. and they only carry the 13/16 and the 7/8.
    off to autozone... ordered the MC, but it didnt say on the computer what size it was so we will see tomorrow when it comes in. i hope its the right one :(
    i dont understand how someone can stock the wrong part for a car. like what if i was some average joe with a 90-91 EX. i walk in and they give me the wrong part repeatedly. or dont know any better and install the 13/16 or 7/8 to replace the 15/16. its just stupid. if you dont stock it, dont put another part in its place.
    [/rant]
  11. GSRCRXsi
    MD
    also, one thing to note is that when you replace the MC you will actually have to press harder to get the same brake effect, but as B said the pedal will have less travel. im not sure if this is the case when you match the booster with the MC though.
  12. xj0hnx
    C.C.TX.
    I was wondering the same thing about the booster too. I have the GSR booster and a VTi 15/16's MC with the ears facing the opposite way of the Civics, but I am going to have to cut and reflare the fitting, as one of the outlets is bigger. I was under the impression by looking at it, that the booster only moved the plunger inside the MC, though I guess they could have different travel distances, any one know?
  13. pissedoffsol
    ctr's are different... you're going to have to bend hard lines and reflare.
  14. pissedoffsol
    if you're going to go through all that hassel, you might as well get an ITR 1".
    the only reason to go with the 15/16 from the 91 ex is ease.
    i had a compelte gsr master and booster in my garage, but i decided that it was too much work, and just went with the upgraded master.
  15. xj0hnx
    C.C.TX.
    Yea, I just was wondering if the GSR booster and the Civic booster had the same or different travel differences. I doubt it, but hey, why not ask. I am more than likely going to be doing all this next weekend, as I am going this week to the Honda guy to find a conversion.
  16. pissedoffsol
    the gsr booster is much bigger. you may even have a hard time getting it into position, as it will hit the intake manifold.
  17. phunky.buddha
    Are you sure? Mine fit just fine.
  18. E_SolSi
    ive got an ITR master and booster in the sol with no problems
    getting the booster in after the swap was a bit of a pain in the ass but everything fits fine once its all in possition
    :shrug:
  19. xj0hnx
    C.C.TX.
    I'm not talking about the physical size, I am wondering about the actuating rod inside of it, the one the pushes the plunger in teh MC, if it has more travel. I can fit the booster (not going to, just going to use the 91EX I have and sell the GSR/VTi combo). If need be, the rear mount can be unbolted and sway the motor forward to fit :)
  20. pissedoffsol
    you guys have itr/b16 heads.
    the gsr IM is weird... and the iab thingge is in the way
