Honda on Meth
I am pretty new to Honda's but I did run my first Integra on my chassis dyno last night and it was pretty strong. B-20 bottom with an RS-Vtec head 192 RWHP and I think there is room for a lot more.
Anyway, Meth only makes 1/2 of the BTU's of gas so you have to use twice as much to make the same power output. Sprint cars have huge fuel cells and pumps as they have to pump 2x the fuel. I do not see how it would be any cheaper and the US gov't has not done the math yet. I guess only us dumbass old school racers have that figured out.
Another thing to consider is that if you are using twice the liquid fuel you are going to displace a significant amount of air volume in your intake runners and head reducing the amount of air you can burn ( although meth only requires about 15% -20% more air volume than gas to combust). Bottom line you need more head flow and volume to run Methanol.
The good - It loves compression, It burns cool, it loves turbo's, and it used to be cheap...
The bad - not readily available, not really that cheap when you actually get to running on it and it does not like high under hood temps and big weather changes, and it sucks up water / humidity like a sponge.
The ugly - It corrodes everything, it is abrasive to all of your engine parts and you will have to switch to a special oil like I just had brewed up for me for a couple import projects just like you are talking about. Normal petro or synth oils will not work well with Methanol.
Anyway just my 2c worth.
THX,
Mark
PerformanceChassisDyno.com
