T terror_si Junior Member Feb 6, 2007 #1 if the main relay goes bad will it stop the pulse to the injectors can some one please help me this is the last thing i have to do to the car
T terror_si Junior Member Feb 6, 2007 #2 no the pump is coming on will run with starting fluid but no injector pulse what could make the injectors stop pulsing
Andrew Active Member Feb 7, 2007 #3 Blanco said: Have you checked for ECU codes yet? Did you have to do any wiring and if so what did you do? We'll need more info. Click to expand... x2. You might be throwing a fuel system code or something. Check it out.
T terror_si Junior Member Feb 7, 2007 #5 yes we made a harness from scratch and it ran but would'nt start one day i woke up and had no inj pulse, the was locked and no one touched the car
