miata rims
Discussion in 'Wheels / Suspension / Tires / Brakes' started by highperboi, Dec 18, 2003.
  1. highperboi
    highperboi Senior Member
    Alameda, California
    I just painted these miata rims and put azenis on them. I tried them out yesturday and i felt lots of vibration. I found out that the hole in the center of the rim was to small for the hub to go through so i got these spacer things. The vibration is gone but is it safe to use them??
  2. E_SolSi
    for road use it will be ok ... but id be a little sketchy on using them for hard driving
    do you know anyone at a machine shop????
    you could just get the holes bored out a little to fit :)
  3. SubCultureNM
    SubCultureNM Junior Member
    Increasing the center bore would be preferable, but if you are using the thinnest spacers possible and still have sufficient wheel stud showing through, then you'll be fine, even for hard driving.
    Brian
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yip, as long as you maintain a good amount of threading on the lugs you're fine. People here use tham all the time to get a wider stance, crazy europeons.
  5. highperboi
    Alameda, California
    i think i have enough thred... they were 3mm spacers.
    thanks guys
