Micro Turbo?
machine
Banned
a little away from honda... whats the smallest trubo yall have seen? I want to turbo a go kart, bear in mind this is a singl piston motor....
i think the smallest i have seen come on stock cars like vw.
i would be careful cause even small tubos can put out alot for a single piston engine and if the engine is sitting next to you and you blow it, it might be dangerous.
i know at www.theoldone.com on the forums there's a guy who use to work with cart race engines and is very knowable he would be able to help with advice.
Look under ask T.O.O
hope it helps.
turbo bar stool owns
IHI makes some really teeny tiny turbos- as well as quite a few OEM applications. You might want to check them out.
