Ok, I'm done throwing parts at this.
95 EJ1 Obd1, B20, LS trans, P75 ecu.
I did the swap in February. Car ran fine till I got a no start. Threw a new fuel pump and fuel filter in the car and a known good dizzy, ECU, TPS.
I've check the main relay, wiring to and from the ECU, I have good voltage at the injectors. Intermittently and usualy more often than not the car will bog and guzzle fuel from 2000-3500 RPM and most times when I'n not at WOT.
Suggestion, comments. What could be causing this.
Oh yeah, I drove it to and from work yesterday (50 miles) and not a problem. Got home, shut the car off, and boom. Problem was back.
Thanks in advance,
Curt
Thanks in advance,
Curt
