Might buy del sol but has starting issue
Discussion in 'Civic and del Sol - EG and EK' started by spiritofjosh, May 12, 2011.
  1. spiritofjosh
    spiritofjosh know your role!
    ocean gate nj
    I went and talked to a guy selling a mint 94 del sol, looks like it just left the factory. I took it for a test drive, started and ran good and drove really nice. I bought it back, turned off the car then tried to start it again and it started and stalled. Then for a couple minutes wouldn't crank over and finally a minute or two rest it started and sounded fine.And this happened once again 10 minutes later. Before I buy it what could the problem be? He said he installed a new dizzy from honda and mentioned putting in new plugs, i'm thinking it's probably a fuel issue. Any ideas?
  2. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    If its intermitently not cranking the starter and its wiring isnt a bad place to start looking. Check the grounds in the engine bay as well. That is what my Si was doing when it was a ground issue. Simple fix that I threw a lot of money at trying to figure out.
  3. spiritofjosh
    ocean gate nj
    The best way to describe what it was doing is if you ran out of gas and tried to start the car again.
  4. double0Si
    Columbus, Ohio
    Well wad it cranking at all? I thought you meant it wouldn't crank all.
  5. spiritofjosh
    ocean gate nj
    no it cranked fine, everything even sounded good it just seems like it's not getting enough fuel but if that's the case i wouldnt mind if it was just a clogged fuel filter or something minor.
  6. josh_crewdson@y
    josh_crewdson@y New Member
    nova
  7. RHDism
    RHDism Right Hand Drive guru
    Main Relay.
    You should here a second click from the relay once the ignition is turned to the on position.
  8. GlassHeadlights
    Calgary, AB
    Ask for a lower price since it's a "problem" car. ;)
  9. spiritofjosh
    ocean gate nj
    I actually got him to go lower after that happened. How do I check the main relay to see if that's it? I don't wanna go spending tons of money replacing things that are working fine
  10. spiritofjosh
    ocean gate nj
    Nevermind I did research on it, any other ideas in case it's not the main relay?
  11. dc4dude
    dc4dude Member
    chicago, il
    clogged fuel filter... cracked coil casing. ignition control module going bad, cracks in the distributor cap, that allowed moisture inside....
  12. spiritofjosh
    ocean gate nj
    clogged fuel filter was my first guess and hopefully the extent of it but im gonna take a look at the main relay first then fuel filter and injectors. distributor looked new and he said he had the whole thing replaced, whether he did or not i dont know but it looked ok. thanks for the help
  13. RHDism
    If the CEL illuminates once the key is turned to the on position, then turns off after a few seconds, you hear the hum from the fuel pump, and the 2nd click is present, you can likely eliminate the relay. Vise versa if not.
    Clogged fuel filter is unlikely, but not impossible.
  14. spiritofjosh
    ocean gate nj
    When I checked the car out the first thing I looked for was a cel, a few times actually and it didn't come on at all, so I'm really positive it's the main relay, easy fix. Hopefully.
  15. RHDism
    It should illuminate once you turn the key. If its not coming on "at all ", the bulb is either bad, missing or disconnected.
