LS_VTEC
you get the BRAKE
nice. Let me know if you dyno with it, if it made a significant increase.
I just got home. I deglazed and honed the cylinders. Before hand, we removed the crankshaft to discover that it actually had ACL main bearings in it... I know Honda doesnt manufacture their short blocks with ACL bearings, so this block was rebuilt previously. I noticed on the rod journals that one journal had scoring and scratching... I realized that when i was removing the piston/rod from that cylinder, the rod bolt made contact with the journal and damaged it. So now, I have to have that one journal machined, and a new bearing for that journal be needed depending on how much they machine it.
I did not want to remove the crankshaft, but now I have no choice. New Main bearings and thrust bearing will be required so I will get those from the machine shop. Some pic's were taken tonight when we gave it a chemical bath & scrub but the deglaze/hone was a tad bit messy when I did it using ATF transmission fluid so I didn't take any pics of that. The finished product of the cylinder walls will be shown in a couple minutes after I upload the shots I took tonight...
Every cylinder cleaned up 100% wonderful except for cylinder #3, which looks like it could use a line hone, but I can get away with it for the cross hatches did come out great. As far as the ridges are, they were perfect. No ridge on the top of the cylinders at all, nice and smooth.
