"miles per gallon of gas "
Discussion in 'Civic and CRX - EW' started by gcoloma, Sep 18, 2006.
  1. gcoloma
    gcoloma Junior Member
    Hello!
    another newbies in crx I'm planing to buy one a stick shift crx.
    I've been told crx hf will run 50 miles per gallon is this true? and what year has more miles/:) gallon of gas?
  2. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    no. 30 at max.
    my XR650L dirtbike only gets 55-60...
    thats 2 wheels and only a 650
  3. gcoloma
    gee I saw on the adds stick shift crx 1985 si 35miles per gallon and 40-45 crx hf.
    and anothe one has oil leak on the spark plug housing holes is this normal ?
  4. phunky.buddha
    Dallas / Fort Worth, TX
    A CRX HF will get close to 50mpg if not more.
  5. gcoloma
    any year? or a certain type like fuel injector or carburator coz I'm thinking I'm gona buy one instead of electric scooter that runs slow.
  6. phunky.buddha
    The 88-91 HFs will all be fuel injected. Get one of those.
  7. eg6sir
    how can you say only 30 mpg.. my b16 gets 32-39 mpg freeway
  8. Amidon
    Amidon lessweight=morepower
    OH
    I have an 89 HF and get 47 highway. Almost 40 average.
  9. gcoloma
    what to look for when buying this type of car?Stock
    and the engine code is this a b16?t.y.
  10. Amidon
    OH
    d15. look for rust on the underbody. ask when the timing belt was last changed. as long as it's been serviced regularly you should be good. mine's pushing 190,000 and still runs strong.
  11. gcoloma
    I'm in l. A is there any online or classified ads for sale ?
    recycler and craigslists?
  12. eg6sir
    ok.. and your point is.. i'm just saying, with my b16 i get better than 30 MPG.. so, an HF will obviously have higher since its the fuel efficient model..
  13. gcoloma
    so how does a d15 looks like Picture pls. very well apreciated .
  14. cycloneb18c3
    New Jersey
    it looks like any other single cam. you have to look down by the manifold theres the engine code stamped on the block(right by where the tranny and engine meet)
  15. gcoloma
    Thanks ! whats the hp on this?
  16. Amidon
    OH
    62 HP stock. 90 lb.-ft. of torque helps but you're looking at 0to60 over 10 secs.
  17. eg6sir
    well its obvious hes not looking for power if hes concerned on MPG
  18. gcoloma
    so where should I look for more crxhf? googles.com?
  19. eg6sir
    try autotrader.com, craiglist.com
  20. gcoloma
    I saw d15 civic hatch backs does this got the same mpg as crx hf?
