Originally posted by simplyfast@Dec 6 2003, 11:57 PM
the white milky crap on the inside of your oil cap-it is moisture in your oil. you wanna check to see if you have a blown head gasket, simply remove the radiator cap and start the engine. if water spouts up/out, you have a compression leak. this means to any degree. if it slurps half way up, you have a leak. if you constantly have to add water to your radiator, you have a head gasket leak for spent gases will make their into your coolant, causing it to boil over to the over flow tank. you will also be able to smell gas in your coolant.
as for your idle problem...someone said fast idle control valve. they are probably right. if you want to be brave, tear it apart and replace the o-ring you find inside it. if you decide to replace the factory faulty o-ring remember to oil the o-ring so it will be able to seal properly.
the steering problem-who ever told you it was a problem with your alignment should not be allowed anywhere near a car with a wrench, screwdriver, or even tire pressure gauge for that matter. sounds to me like you have an axle going out. while driving my buddies car, a 90 crx si with a factory tuned engine, it did the same thing. what you might have done is loaded the axle while exiting hard from a corner. this is an easy fix that can be done within 11 minutes by an experienced mechanic. (i have timed myself, and my friend. he posted 11 minutes while i posted 14) if you arent an experienced mechanic this would be a good learning experience. you will need a few tools, i believe a 32mm, 17mm, and a 14 mm socket, a tie rod fork, a flat blade screw driver, and a pair of pliers to remove to cotter pin.
