Mini - Fine tuning - Help needed .
Discussion in 'Civic and del Sol - EG and EK' started by osix, Nov 27, 2015.
  1. osix
    osix New Member
    Here some Update - and need some verify
    ECU - P6x-T51 ( Auto - Amazing car is running )
    5 days ago
    Installed 1 Wire O2.
    Result : Mpg Improved Calculated 27 MPG
    Con : No Power - 3rd , 4th 5th gear feel dry and powerless .
    ( D16y8 CAMEAGR )
    Today .
    Installed PM3B Camgear ( Marked 362 )
    not sure if it TDC but did a Screw driver Trick & Place The CAMGEAR as shown on photo .
    Result -
    Car Feel powerful .
    Gear 1 and 2 Rev go up very fast . ( guessing it Compression is working )
    MPG will time over the Next 2 Day .
    Timing is not Adjusted with Flash Gun
    Question and Doubt .
    Current Spec -
    1. Timing belt Tooth is 103
    2. Camshaft - D16Y8
    3. CamGear - D7/D8/Z6 ( PM3B - 362 )
    4. ECU - P6x-T51 ( Auto )
    5. Spark Plug - NGK G-power
    6. D15 Block but weirdly ( refer to photo below - Note there is a Number 14 - i wonder if there is a D14 20151126_152006_611624d12922f49ca1e3b0c0ddc8867b32ff3428.jpg 20151126_152012_83bb8dbb2c19ea29ad3b9a30097a6aea164bb3a2.jpg 20151126_163730_6ddd409317522b81f2180d7dc84b243928c93b46.jpg
    Today i went to set Timing , and i was told i am OFF by about 5 degree some where in the 20 degree range ? or he said i am off by 1 tooth .
    So do i turn the Camgear back Anti clock wise by 1 tooth ? and that it ?
  2. Briansol
    Very strange. i've never seen that casting ever.
    I wouldn't worry about the 14, that is likely the 'casting number', not the displacement. Where it says CV, it should say D15B1 or similar... weird stuff here...
  3. osix
    osix New Member
    I believe this si the Thai version of Civic EX .
    Any idea if the Timing Camgear is set correctly .
