Mini Me Block Questions?
CivicCrx21
Does the mini me swap include use of all D-series blocks?? Can I use a block from a 88HF. Most of the related articles did not mention this block. Just curious as to what my options were.
yep you can use it. Is that the 8 valve one? If it is chek the pistons, some had clearance for 16 valve heads some didn't, or put som P29 pistons from the 89 Integra in it and raise the compression while you are at it.
yeah its the 8 valve monster, how would i be able to tell if i could have clearance for a 16v head? If it doesnt hit???
I just wanna do a quick swap so i can blow this engine upand have a lil fun. I heard the DX head does wonders for the HF???
