In doing a mini me conversion, can i use a dohc zc block with a sohc vtec head? I have a dohc engine and i want to do this swap but i'm wondering if the sohc vtec head can be bolted onto the dohc zc block without. Any suggetion welcomed.
You can use the ZC crankshaft and pistons in a SOHC block, that is it. A SOHC head doesnt fit on a SOHC block, not D series anyways. There was a guy that put a ZC head on a SOHC block but the time it took out weighed the worth of the swap.
