Mini Me Help
Discussion in 'Engine Building' started by dwn2low, Aug 24, 2003.
  1. dwn2low
    dwn2low Senior Member
    Little Rock AR
    Ok I just got all the stuff to put a mini-me together but before I drop it in the car i'm going to turbo it with a b14 (too5) turbo. What can I do as far as aftermarket stuff to build the engine? I know all valvetrane is d16z6 but what about bottom end what pistons will work? Can I put b-series in it or d16 aftermarket ones in?
    Thanks
    Mark
  2. ludegirl
    ludegirl Senior Member
    Southern Cali
    no you cant use b16 parts in your d16 as far as building the bottom end i heard that crower makes really good parts for d16 turbo as i remember hondatuning is doing a budget boost project on a single cam maybe u could go to their web site
  3. convertedstangbanger
    convertedstangbanger Senior Member
    ATX!
    theres alot of mini-me stuff available, just not here. i suggest you look elsewhere.
  4. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
