no the injectors inject at diff times just like two pistons up two pistons down on the block when in motion how you set the timing this is how i do it and it never fails take sparkplug #1 out from the head,move the cam shaft to the nearest point in "UP" position if its hard to move or wont move then turn the crank a lil, when done stick your dipstick in the sparkplug #1 hole and turn crank till its at its very top position then you turn just a lil not even a bit but a lil and you set the block on time the head make sure the arrow for up is at the top slide in belt a whalaa.............iidk if this is right but are all the fuel injectors inject fuel at the same time and how do i set the time on this mini me like how ment degrees do i need to turn the adjustable cam gear and what not
