mini me map sensor
c-rex-beat
yeah, it's a vtec.
I just finished up the mini me swap, using a p28, jumper harness, all that. where is wires for map sensor? I don't recall my 89 having one?
the map sensor is on your firewall. unless you changed the intake manifold as well then the map is still plugged in. if you swapped to a z6 manifold though, then the map will now be on the tb, and you will just need to move your map plug to the tb.
