mini me problems
Discussion in 'General Tech and Maintenance' started by zack zerr, Mar 27, 2009.
  1. zack zerr
    zack zerr New Member
    foley
    got a question.. i got a 90 si hatch with z6 head and p28... it runs but when its cold my oil light isnt on.. as it worms up the oil light gradually comes on...im puzzled help please
  2. zack zerr
    foley
    ok well with this little problem i have decided to make this my play car.... i either want to build my d series and turbo it..... or i want to use my ls block bore it and build it but then i gotta buy a tranny and a vtec head, mounts and wiring...then turbo it.. which would be the best? i wanna spend like 4 grand... no more
  3. 97hatch
    97hatch ?
    Anderson IN
    oil light coming on after car warms up would indicate that the motor is probaly toast and on its last leg that light dosent come on till the pressure is below like 3psi or some thing
    it only does it when it warm because the oil gets thin as it warms up and the bearings are to loose to hold pressure
  4. ihatemyprelude
    ihatemyprelude New Member
    Ocala, FL
    dont waste the money, for less then 1000$ you can have a new motor ( less then 55k) for what you spend for gaskits,rings, new rods, new crank, all the seals and bearings new head studs, its cheaper and easier to do a swap.
    JDM Engine Depot
