mini me question
Discussion in 'Civic and CRX - EF' started by Bobby17772, Sep 30, 2009.
Thread Status:
Not open for further replies.
  1. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    I was looking online and I came across this article D16A6 to D16Z6 Conversion..."Mini-Me"
    the one thing that I'm wondering is even though I've got a d15b2 but I'm doing a mpfi swap that would give it the si dizzy and I've already got a z6 intake mani, wouldn't that kind of make it like the a6?
    thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    almost but the a6 has a bit longer stroke, the bottom end is different as well as the head its self
  3. Bobby17772
    Enfield, CT
    alright, so even if the head bolts up it doesn't mean that it would work because it wouldn't have enough compression?
  4. AHHVTEC
    Alabama
    nah you can put a z6 head on there and it should work fine
  5. Bobby17772
    Enfield, CT
    awesome. Thanks a lot!!
  6. Bobby17772
    Enfield, CT
    seeing that the z6 has a bore and stroke of 75 x 90 and the b2 has one of 75 x 84.5 how much would that change the compression because thats 5.5mm difference
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    itll probably lower it a little bit..
    but why dont you find a 1.6 block around ct?
  8. Bobby17772
    Enfield, CT
    idk, kind of want to work with what I got, and make it better
  9. Bobby17772
    Enfield, CT
    wow I was just looking on SolBlu's Helpful Del Sol Site and seeing that the d15b7 is pretty much the same as the b2, I used that as the block and it said that it should jack it up to 9.84:1 from 9.1:1 thats pretty good
  10. GlassHeadlights
    Calgary, AB
    If you got a block such as a D16A6 it would go right to 10:1, the D16's have bigger bearing journals than the D15's too theres no downside.
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    word i dunno if you wanna stick with th 15 then go ahead,but i feel the 1.6 have more support
  12. Bobby17772
    Enfield, CT
    oh no the d16 defiantly has better support. But I did get some good news. I had to give me friend a ride home today but we stopped at his nephews house and he's get a 91 integra ls just sitting there, he also has an 89 integra that if I go a head gasket, a tune up, and a few little things for him, I can pretty much have the engine and tranny, and probably the axles, the bad news is that it's got a misfire in cylinder #1, but that could be anything
  13. INJEN78
    INJEN78 HS LEGEND
    OHIO
    so youll be getting what?
  14. Bobby17772
    Enfield, CT
    I still may do a half assed mini me on this engine, but I'll get the 1.8 ls engine, tranny, and maybe the axles. Just for doing a head gasket, a tune up, and maybe a few other things.
  15. 78civic
    78civic Junior Member
    NW MS, Y'all
    If I were you, I'd fix nephs' car, do a quick rebuild/re-ring to the LS, find some hotter cams and swap that in once you get all the parts together.
    From what's said, you would have enough torque to keep you smiling even after you get to work/school.
    E
  16. INJEN78
    INJEN78 HS LEGEND
    OHIO
    the ls is actually a pretty simple swap..and will give you more hp than doing the minime..get the ls and let us know if you need any help.
  17. 91civisedaner
    91civisedaner Senior Citizen
    oregon city or
    so are you getting the 91 or the 89??? cuz the 89 would not work for your car..
  18. INJEN78
    INJEN78 HS LEGEND
    OHIO
    how wouldnt it???? its a zc
  19. Bobby17772
    Enfield, CT
    the one out of the 91
  20. INJEN78
    INJEN78 HS LEGEND
    OHIO
    is the teg a standard???if so take everything..
    motor,tranny,axles,ecu,you can even take the wiring harness..only thing that wouldnt work is mounts,and shift linkage,,but you should also take the rear mount bracket..its a necessity for this swap
Thread Status:
