Mini me swap
Discussion in 'Engine Building' started by calvin, Oct 14, 2002.
  1. calvin
    calvin Senior Member
    NETHERLANDS
    Hi people,
    the mini-me swap was a succes.
    Problems:
    -Spark pulg wires dxi d157 doesn't fit on d16z6 head.
    -Timingbelt cover upper peace doesn't fit.
    -COULDN'T GET THE CRANK SHAFT BOLT LOSE.!!!!!!!!!!!!!! :angry:
    I'm using my dxi distrubutor. only tighted with 2 bolts. Think this is a problem?
    Tommorw i'll will put the p28 ecu
    Checked the vtec it works oke but when the vtec comes in the old ecu revs the car. ;)
    Regards, Calvin
  2. pissedoffsol
    i'd wait to do more testing until you ahve the ecu in. otheriwse, you are going to run into less/more problems based on the ecu swap-- you know?
  3. calvin
    NETHERLANDS
    yes i know that
  4. RoadRage
    RoadRage Member
    Ran somebody the other day (Mini Me Swap). They whooped up on my wheel hopping LS swap in my rex................Bastard's
    But once it's all done, That is a good and cost effective swap.
  5. calvin
    NETHERLANDS
    I have put my new ecu, every thing oke
