mini-me swap
Discussion in 'HYBRID -> EG-EK / DC' started by Jason808, Feb 23, 2010.
  1. Jason808
    Jason808 New Member
    hey, i decided to sell my b18a1. and picked up a d15b with a y8 head.
    (mini-me $200;))
    what will i need to drop that motor into my 99 civic. it had a d16y8 motor but it blew.
    so should everything just be plug-in? :confused: I'm going to re-use my y8 dizzy.
    thanks,
  2. d-mon
    d-mon what r u compensating 4?
    everything but the knock sensor.... crank pos. sensor...
    and alternator plug.
  3. Jason808
    Jason808 New Member
    Could I use my y8 alternator?
    And could I run it without the knock sensor and the crank pos. sensor?
  4. d-mon
    i recommend using the y8 alt.
    you will get CELs for the other, don't know how well it will run. crank pos is kinda important...
    the good news is you can use your y8 distributor.
  5. Jason808
    Jason808 New Member
    what will i need to do to get the crank pos. sensor working?
    thanks for helping,
  6. d-mon
    a y8/y7 oil pump.
    but, i don't know if it will fit a d15b7 block.
    then you will have two dipstick holes...
    also, some people have drilled and tapped their block for the knock sensor.
    watch where the metal shavings go if you try that.
    or, depending on what state you live in you could do an obd1 swap.
    get a p28 ecu and an obd2b/obd1 conversion harness.
  7. Jason808
    Jason808 New Member
    Hmm I think I'll go with the p28.obd1 doesn't need the crank pos.sensor right?
  8. d-mon
    i think OBD1 has it in the distributor. not the oil pump.
    and doesn't use a knock sensor
  9. Jason808
    Jason808 New Member
    Oh.so what distributor do I use?
    The y8?
  10. d-mon
    for obd1, use the d15b7, or td-41u distributor.
  11. Jason808
    Jason808 New Member
    Ok,hey thanks a lot man u answered everything I needed to know for the swap.gonna rebuild it and get it turbo ready.
    Again thanks a lot man.
