mini-me timing
Discussion in 'HYBRID -> EG-EK / DC' started by hamorhead, Jan 15, 2009.
  1. hamorhead
    hamorhead New Member
    Melbourne FL
    i have a z6 head im putting on my b8 block my question is how do i make sure the person that had the z6 head put it to TDC b4 they took it off...also how should the timing be set will the marks line up and work correctly?
  2. Gunni
    Gunni New Member
    iceland
    hehe u dont have to put the head to tdc. and the mark line up and will work fine
  3. hamorhead
    Melbourne FL
    yea i do cuz if i dont i will bend a valve
    but i figured it out
  4. rudebwoy
    rudebwoy New Member
    everything needs to be at TDC before you reinstall the timing belt.
    use the marks on the cam sprocket, should be an arrow with UP on it. or 2 marks to flush it with the head surface.
  5. frankinstine2000ek
    frankinstine2000ek New Member
