Mini Swap
Discussion in 'HYBRID -> EG-EK / DC' started by Bobo HC3D, Feb 24, 2003.
  1. Bobo HC3D
    Bobo HC3D Member
    Poland Warsaw
    Is there a way to do a head swap as to mount a D16 head on a D15Z6 engine? :worthy:
  2. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    I think your confused. You probably mean D16Z6, which has a D16 head, the best d series head, so, yes?
  3. Havok
    Havok Senior Member
    Florida
    There is no D15Z6, it's a D16Z6 which already has vtec, or a D15Z1--either case, both of them have vtec, so I'm not sure what you are asking.
  4. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    If you have a 5th gen, most likely you have a d15b7. You can get the z6 head and swap it, get the ECU, wire up vtec and have a mini-me.
    BTW.. y8 head/IM is the best d-series head. Smaller Combustion chambers and the IM is called the "itr IM of the d-series".
    Search for mini-me and you will get a LOT of threads on it.
  5. ilovebrittany
    ilovebrittany Junior Member
    would this work on the d15b2? i just baught an 89 civic hatch and i have less money left over than i expected :( so no zc and a b series is deff. out of the question.
  6. TRuggiero_
    Winter Garbage, Fl
    Yea, almost all d-series heads and blocks are interchangeable.
  7. Bobo HC3D
    Bobo HC3D Member
    Poland Warsaw
    BUT MY ENGINE IS A D15Z6 :rolleyes:
    it has 114HP stock
    check it on a honda web page
    Soo i repeat my question .. would a D16 head would fit on my D15z6 block or whatever.
    Thanx
  8. kyleirwin
    kyleirwin Retired OG
    Vegas
    he's right, he does have a d15z6. it's not listed in the ref. section, but it does exist. it came in 6th gen edm civic iLS's i believe. as for the question, there should be no problem swapping on a d16 head, although it probably won't yeild too high of results... if any. they're both sohc vtec heads. i don't know much about that engine, but i'm just assuming it's very similar to the d16z6 here in the states, the only difference might be the larger displacement of the d16.
  9. Bobo HC3D
    Bobo HC3D Member
    Poland Warsaw
    For sure I'll gain some torque.
    Its also much cheaper than a complete swap.
    also the engine serial numbers are not on the head so its cheaper to find some bargain engine on flee market.
    Remember guys I live in Poland :)
    http://www.cardomain.com/id/mrbogdan
    have a look @ my ride
  10. kyleirwin
    Vegas
  11. pissedoffsol
    swapping the head is a waste of time if you ask me.
    consider swapping the cam and the computer. i bet thats most of the difference.
