MINIME siy8
Discussion in 'Engine Building' started by hybrid4, Mar 31, 2004.
  1. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    I heard you can remove the oil jet (intake side of block between #1 and 2 cyl.) sence there is one in the y8 head in the same spot. Is that true? If so, i have to take the head off again. Will it hurt to keep it in there? And how do you get the jet out? Finnaly, Can i reuse my head gasket? Its a new one. Im running the a6 gasket right now and my cr is 160 psi, a little high. Thanks
  2. hybrid4
    Nashville,TN
    :beer: :sleep:
  3. h82w8
    h82w8 Senior Member
    orlando,florida
    to remove the jet you screw a screw that is close to the diameter of the i.d. of the jet in to it and pull the whole thing out with a pair of pliers.
  4. CRX2NR18
    CRX2NR18 Senior Member
    yes u have to take it out because vtec will not ever engage if its in there... sorry man but u gotta take it back apart
  5. hybrid4
    Nashville,TN
    Cool, i was looking for an excuse to work on it anyway. Thanks guys! :thumbsup:
  6. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    To answer the second part of your question, if you have torqued the head down on this head gasket, you cannot reuse it.
  7. hybrid4
    Nashville,TN
