minime valves
INJEN78
HS LEGEND
ok soo we are finishiong up the minime swap on my brothers civic si..we put a z6 head on an a6 block...i looked all over the haynes manual and cant find what the valves need to be adjusted to..maybe im just looking past it??
does anyone know off the top off their head what they need to be adjusted to??
also can someone help me double check my work??is there anything i might need to make it run right??
we swapped heads.a6 manifold,injectors,rail,pressure reg(do i need an adjustable?. on the z6 head with z6 cam/gear(do i need an adjustable?
Specs:
Exhaust: .009-.011"
Intake: .007-.009"
i think i might have found the specs..could someone please verify
