Alright.
basically, i've got the car into the state where the CEL does not come on since i cleared the TPS code. i've driven ~1500 miles since then (after i reset the ECU) and it still reads "NOT READY" at the inspector. same results with BOTH ECU's... 97 and 00 1.5 5spd ECU.
I'm fighting MIL (malfunction indicator lamp )codes now
5 incomplete -
EGR
EVAP
o2 heater
o2 sensor
catalyst
im thinking i need to clean the EGR to clear that code...
obviously im running 1 cat, and 1 o2... with the simulator.
not sure why EVAP is failing.
put the sniffer on the car, it passes easily. any ideas that do not involve adding the 2nd cat or o2 sensor? i'm SICK of exhaust work.
5 incomplete -
EGR
EVAP
o2 heater
o2 sensor
catalyst
