misc b series parts including block and crank
Discussion in 'Parts: For Sale/Trade/Wanted' started by SoSlo, Dec 28, 2006.
  1. SoSlo
    SoSlo Member
    nor cal
    b series garage sale
    UPDATED
    JDM B16A short block odb0(dissasembled-cleaned-reassembled)_$150
    JDM B16A short block obd1 (complete ready for a head)________$150
    b18a1 head with all valvetrain______________________________$35
    jdm b18c crank (need to be polished has 1 spun rod bearing)_____$75
    b series oil pump(used)____________________________________$15
    ls water pump(used)_______________________________________$10
    ls timing belt(used)________________________________________$10
    b series oil pickup_________________________________________$15
    b series coolant tube with thermostat housing(used)_____________$20
    b series water pump(used) _________________________________$10
    b series idler pulley(used)___________________________________$5
    b16 tranny brace_________________________________________$5
    obd2 crank angle sensor___________________________________$15
    obd 2 timingbelt crank pulley(chipped)________________________$5
    obd 1 timingbelt crank pulley_______________________________$15
    vx (13/16) brake master cylinder____________________________$5
    obd 1 gsr distributer_______________________________________$75
    gsr crank pulley___________________________________________$30
    gsr flywheel______________________________________________$10
    4 gsr pistons on rods______________________________________$35
    4 b16 rods(rods scratched but usable)________________________$10
    3 usdm gsr pistons with wrist pins____________________________$10
    2 jdm gsr pistons with wrist pins______________________________$5
    blue eg steering wheel______________________________________$10
    full srs wiring harness with sensors and steering columb slide and srs ecu__$25
    drive side eg manual mirror___________________________________$5
    everything is OBO
    i am paypal certified
    hit me up at smmccurdy@hotmail.com
  2. SoSlo
    SoSlo Member
    nor cal
    bump
  3. sprayit500
    sprayit500 New Member
    does the dizzy work? i need the gsr dizzy, gsr flywheel, and gsr pully. how much 4 every thing? with shipping to 16127. thanks
  4. SoSlo
    SoSlo Member
    nor cal
  5. SoSlo
    SoSlo Member
    nor cal
  6. broadway7272
    broadway7272 Junior Member
    hey would you be willing to ship obd1 b16 block, if so could you estimate to 07072, carlstadt nj
  7. SoSlo
    SoSlo Member
    nor cal
    $150 just due to shipping teh flywheel is heavy
  8. SoSlo
    SoSlo Member
    nor cal
    shipping will run about $175 so ill do $325 shipped
    just let me know
  9. SoSlo
    SoSlo Member
    nor cal
