Mishimoto radiator with Innovative traction bar?
kg728
I've done some searching and can't seem to find an answer to my question...
I'm just wondering if anyone knows whether the mishimoto full size radiator for the crx will fit fine with an innovative traction bar... and if not, do you know any crossmembers/traction bars that would?
From my personal experience, ETD/K-Tuned was the only bar I had to bend the mounts with(luckily I didn't remove them). Avid and ESP work completely fine and from reviews the Innovative looks like it would work too. Pretty much any that does not require removal or modification of the stock radiator mounts will work.
The innovative traction bar for the EF if I remember correctly is designed to fit the stock radiator, so the Mishimoto replacement size radiator should fit just fine .
