mismatched integra
Discussion in 'HYBRID -> EG-EK / DC' started by 92colesi, Feb 3, 2009.
  1. 92colesi
    92colesi New Member
    434 VA
    A good friend of mine is looking at buying a 96 gsr. Here's the catch. It's got a b16a1, running on an ls wiring harness and ls ecu. Tach doesn't work because of the harness, nor does vtec. Aside from changing the ecu, what else needs to be done to get this beast running properly? Thanks in advance guys! :confused:
  2. je power
    je power New Member
    my house
    i got to wire in vtec to ur ecu its not hard its 2 wires
  3. get_nick
    Washington State
    i'd stay away from it. unless it is $2000, i wouldn't want to buy it. who knows what else could be wrong with it.
  4. welfare
    welfare Ancient Member
    New York
    the tach should work regardless of what harness is used
    vtec should work if you get a vtec ecu and wire in the vtec, check the wiring diagrams in the refrence section, then follow the wiring.
