Misses when hott!!!!!????
Discussion in 'General Tech and Maintenance' started by Hondatuner88, Aug 21, 2005.
  1. Hondatuner88
    Hondatuner88 Senior Member
    Hey guys..Just resently I found out that my 94 hatch with a d16z6 misses when hot in the lower rpms...I don't understand why its doing this...Everythings stock..Im waiting for a motor so I can build an all motor lsvtec this winter...Could this be the plugs n wires or cap n rotor? This motors just gotta last me few more months...Please someone help me out!!!!
    Thanks,
    Koby
  2. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    check to see if your ECU is throwing any codes. it's probably your o2 sensor.
  3. Hondatuner88
    Nope...Not throwing any codes....anyone don't know my problem?? Someone please help me!!!
    Thanks,
    Koby
  4. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Well, first i would try a basic tune up, then the o2 sensor as suggested. :unsure:
  5. hybrid89
    hybrid89 thistownsucks...
    SoCal
    bad cat?...an O2 sensor would throw a code!
  6. VTECin5th
    Phoenix Az
    a non functioning o2 sensor would throw a code.
    An o2 sensor in the middle of going bad, or not completely bad will not.
    In my 89 prelude i had 2 o2 sensors and neither threw codes, and both of them were bad.
    As soon as my car warmed up it would misfire until around 3k rpms then clear itself up and go normal.
    After replacing both, everything was perfect again.
  7. vtecjdm
    vtecjdm Senior Member
    i`d say begin by checking the dizzy (rotor and cap) ... then coil, ignitor .. and all the rest
