missing second at high rev's
probably the transmission... does the throw out bearing make a lot of noise when you are sitting in neutral and you let the clutch out?
yeah when im sitting in neutral with the clutch out its noisy, ill try replacing the throw out bea ring and go from there. thanks guys
