Ignore about 90% of the speculation you just heard above. Here is the double truth Ruth...
the 2G Eclipse Turbo 4G63 is a strong motor yet can be weak. They can hande aroudn 400wHP when tuned properly. The downfall of a 95+ car is that many have a manufacturing issue with proper oiling to the crank thrust bearing and the crank can go at any time. There is a known fix for it which relates to drilling an additional oiling hole in the crank journal. Heavy pressure plates putting extra strain on the crank have an effect on this.
btw: 1G's did NOT have the problem.
btw: 2G's were about 50-60% problematic.
People saying the motors are shit blah blah blah... my friend blew up three of them etc... is bullshit. They are a motor that needs maintance and care. You have to religously replace the timing belt, tbelt pulley, and hydraulic tensioner every 60K miles. You need to properly tune the car when turning the boost up. I've had about 6 Eclipse/Talons, and 3 Galant VR4's and none of them ever blew up. I went 12.5@109 with about $1500 in mods and 13.0 with about 600 in mods. 13.6 in my GVR4 with $1000 in mods.
The tranny are the weak point of the car but again this is 90% from abuse. It's from launching off the rev limiter, power shifting gears, and dropping the clutch. I've blown up 3 trannys in 8 years and every one was due to me being an ass. On the contrary I've had others for a long time with no problems when respecting them.
There is a saying that many of you Honda guys NEED to learn.... "If you're not breaking things you're not making enough power".
Honda tranny's blow up with 400HP, Honda motors blow up with 400HP. Any little 4 cylinder import that came with 150-200hp breaks and or blows up when you double or more the power.
BTW: ALso the power loss differential from fwd to awd is very small. Dan from Pruven Peformance went from his fwd dyno to awd and only dynoed a slight loss before and after on his old black eclipse. It was about 5% loss. IF you're gonna do an eclipse do an AWD. It's a no brainer. You'll never hook up a fwd'er without spending mad money on an LSD diff, stickies, AWD halfshaft and driver side axle and stickies.
The best car you can do is a 93-94 Talon AWD or Eclipse GSX. THe motor is only second to the 90-91 Big Rod 6 bolt crank motor and it has the better transmission, 4 bolt strong rear end, and bigger dual piston calipers in front.
Here is a pc of my little sled...
