mitsubishi info?
Discussion in 'Other Vehicle Discussions' started by INJEN78, Jan 30, 2008.
  1. INJEN78
    INJEN78 HS LEGEND
    OHIO
    anybody know anything about eclipse???
    my bro is either picking up a 95 rs with a 4g63(2.0 non turbo), or a 93(1.8non turbo)
    i was just wondering what to look out for when looking at them..,good,bad...\
    and anyone have any info sites for these??
  2. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Look for a GSX badge. Turbo AWD.
    Gs-T is turbo FF.
    It would be a good idea to get one with a 4g63 that's a good engine for boost. Even if he doesn't boost it's a good engine all around.
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yea gsxis a sick setup...
    but they are only $500 each....the 95 needs a map sensor..so if he gets it,,hes dropping like 1g on other shit for it...the car looks straight..
  4. 93civicracer
    Texas
    Make sure all the bumpers etc. line up to see if it was wrecked and when you open the hood check the frame under there. When I bought the civic I didn't check and it turns out the front-frame/radiator support is bent so the radiator sits high and the hood slams on it it was obviously wrecked.
    The 95-99 model Eclipse's have the best body IMO they look fuckin cool. I say find a working MAP sensor for it and test drive see if it's all good and that's the only problem. Got pics?
    edit - and if he's spending about $1,000 after the purchase get a 98 front bumper I think that's the year it looks sweet.
  5. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    The non turbos have more problems than the turbos......
  6. TurboMirage
    eclipses have MAFs not MAPs.
    the 2G RS is the 2.0L 420a, NOT the 4g63.
    the 1G non4g63 is the 4g37, which is basically my motor with a longer stroke and MAF.
  7. 93civicracer
    Texas
    Do you know if it was swapped?
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    mind going into detail??!?!i have heard about crank walk in the 4g63
    ahh ok,,now he said the car will need to be towed away..he said i could fix it there if i wanted...soo would the MAF cause it to not start??
    i dont think it was,,and heres the ad
    Great shape!!! 95 mitsubishi Eclipse
  9. TurboMirage
    it may or may not. if the MAF was disconnected and the car has not run in awhile it may not start.
    looks good though ;)
  10. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    u sure bout them not havin maps? i'm pretty sure my buddy's talon has a maf and map. all i can remember is bitching about it having both when we pulled his motor for the rebuild. idk, it was a long while ago.
  11. get_nick
    Washington State
    buying any car under $2000 is going to have issues. this will cost more in the long run than buying a real car to begin with.
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yea,,im pretty sure this car does have a map sensor...i was on mitsubishiforum and someone said it will just have a maf sensor if its turbo..but this is an rs(non-turbo)so it does have a map sensor...
    i understand that buying a car under 2k will have problems but thats why im trying to get opinions,,,,im just trying to figure out if i should take the guys word for it and pickup the car and do the sensor at home....or should i buy the map sensor and attempt to fix it there...
    and this is for my bro,,he just turned 16 and has 1300 to spend on a car..he bought the civic that i currently own,and it was nothing but a problem,,hes just trying to get something that will be a cheap fix,so he can learn to drive on
  13. YBLEGAL
    NW Indiana
    i ment even on the turbo cars. because there's a point where you dont have boost, but just vacuum. so it would appear to me it would need a map.
    my friend's talon had/has a turbo 6-bolt 4G63
  14. get_nick
    Washington State
    if he has limited funds, he should look into an ef civic or a crx. cheap, easy to fix, and reliable. plus, when he gets money he can throw in a b16 swap or something. never ever buy an unfamiliar platform just because it's cheap.
  15. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i tried talking him into another civic,,he said the eclipse is like a dream car,
  16. 93civicracer
    Texas
    I used to drool over Eclipses too. Until I found out how cheap and easy it is to work with Civics and actually I'm looking for an 89-91 crx si or civic hatch si to trade the sedan for after I finish up with some problems.
  17. TurboMirage
    i paid 1200 and 1300 for my mirages, and the only problems with those vehicles were caused by me directly.
    your statement is not always the case.
  18. lewellgd
    lewellgd 92CivicHatchCxBORNINCALI
    this is HONDASWAP----- I think your looking for MITSIBISHISWAP---- if there is one-- lol im bored and no nothing about DSM sorry just ignore me
  19. get_nick
    Washington State
    well, for the most part, if a 16 year old kid buys a very cheap car, there will be problems. they will drive it hard, hit shit and not keep up the routine maintenence. but there are some that can maintain and upkeep the car.
  20. redgsr
    redgsr New Member
    I'm pretty sure DSM's have tranny problems, most of the ones i'm seen have gear grinding problems. And i'd watch out for ball joints too.
