** mizu aluminum radiators, fans, hoses specials **
Discussion in 'Vendor Classifieds' started by HA Motorsports, Mar 3, 2010.
  1. HA Motorsports
    HA Motorsports New Member
    We bring to you a new lineup of Cooling Products:
    MIZU Aluminum Radiators, MIZU Aluminum Fan Shrouds, MIZU Radiator Fans, and MIZU Silicone Hoses.
    ** ALL MIZU PRODUCTS FEATURE A LIFETIME MANUFACTURER'S WARRANTY **
    [HIGHLIGHT]YOU MUST CALL IN YOUR ORDER AS THESE SPECIALS ARE NOT AVAILABLE THROUGH OUR ONLINE STORE 209-324-9880[/HIGHLIGHT]
    HA Motorsports
    209-324-9880
    www.hamotorsports.com
    Mizu aluminum radiators are hand welded and hand made to create a perfect, one of a kind aluminum radiator that is designed to fit perfect in the factory location without any cutting or modification of any kind. Mizu Aluminum radiators increase cooling capability through their thicker three row core and denser fins. All Mizu radiators come standard with a high pressure 1.3 bar Mizu radiator cap.
    MIZU ALUMINUM RADIATORS AVAILABLE:
    90-93 Integra (p/n R-INT-90) $210.00 SHIPPED
    88-91 Civic/CRX (R-CRX-88) $225.00 SHIPPED
    92-00 Civic / 93-97 Del Sol (p/n R-CIV-92) $187.50 SHIPPED
    01-05 Civic (p/n R-CIV-01) $247.50 SHIPPED
    06+ Civic SI (p/n R-CIV-06SI) $240 SHIPPED
    94-01 Integra (p/n R-INT-94) $210.00 SHIPPED
    02-04 RSX (p/n R-RSX-02) $232.50 SHIPPED
    97-01 Prelude (p/n R-PRE-97) $225.00 SHIPPED
    00-05 S2000 (p/n R-S2K-000) $240.00 SHIPPED
    Mizu electric fans are engineered to keep your car running cooler by increasing the fans speed, allowing more cool air to flow through your radiator. Mizu electric fans have a unique slim design allowing them to be mounted flush against your radiator. Mizu electric fans are backed by Mizu's lifetime warranty!
    MIZU ELECTRIC FANS:
    10" Universal Slim-Line Electric Fan (p/n F-10) $60.00 SHIPPED IF PURCHASED WITH RADIATOR
    12" Universal Slim-Line Electric Fan (p/n F-12) $63.75 SHIPPED IF PURCHASED WITH RADIATOR
    MIZU Universal Electric Fan Mount Kit (use one kit per fan)(p/n F-MOUNT) $10.00 SHIPPED WHEN ORDERED WITH FAN AND RADIATOR
    The Mizu Aluminum fan shroud kit is an alternative to installing Mizu universal electric fans. The Mizu aluminum radiator fan shroud comes with Mizu fans pre-installed and offers increased cooling ability over standard fans. It is the perfect upgrade from your existing fan shroud and helps cool your engine when used in conjunction with your Mizu aluminum radiator. Made from the highest grade of aluminum, all Mizu fan shroud kits are hand-welded and hand-made to create a perfect fan shroud with a direct fitment with Mizu aluminum radiators without any cutting or modification needed. Mizu aluminum fan shroud kits enhance your cars performance by its light weight aluminum structure and its heat eliminating composition thus allowing your car to remain both cooler and lighter. All Mizu fan shroud kits come complete with Mizu slim line radiator fans.
    MIZU ALUMINUM RADIATOR FAN SHROUD KITS:
    88-91 Civic / CRX (p/n FS-CRX-88) $185.50 SHIPPED
    92-00 Civic / 93-97 Del Sol (p/n FS-CIV-92) $129.50 SHIPPED
    06+ Civic SI (p/n FS-CIV-06SI) $185.50 SHIPPED
    90-93 Integra (p/n FS-INT-90) $171.50 SHIPPED
    94-01 Integra (p/n FS-INT-94) $185.50 SHIPPED
    02-04 RSX (p/n FS-RSX-02) $185.50 SHIPPED
    97-01 Prelude (p/n FS-PRE-97) $185.50 SHIPPED
    00-05 S2000 (p/n FS-S2K-00) $185.50 SHIPPED
  2. Magana559
    Magana559 The Warden
    fresno Ca
    do you do local pick ups?
  3. EKDriv3r
    EKDriv3r New Member
    What I fail to understand is that these knock-offs are the same exact price as their brand named conterpart, Mishimoto.
    Can someone explain this to me? I thought the knock-off company usually priced their stuff cheaper??? Right??
  4. HA Motorsports
    "Lifetime Manufacturer's Warranty on these"
