going to make brackets off the frame rail using 2x2 square tube. probably overkill since im welding to the frame but oh well. after working out some measurements with a ruler, i've found im going to make the brackets 9.5 inches long and add on an extra inch outward toward the bar to fill the gap. i have some things i have to move a bit first though, and the new headerback (catless) will go on next week so i can finish the drivers side bracket.
the plan:
once the brackets are up and welded into place im going to weld the grade 8 nuts to the inside of the square tube. hooray!
finished the other side finally. here are the results!
my welds are pretty nice for no gas.
the brackets are a few inches too long. going to have to cut them down after cutting the metal plate to match the frame. then weld the plate to each bracket and bolt it to the car.
