more fing problems with my swap
Discussion in 'HYBRID -> ED-EF / DA' started by erebunicrx, May 29, 2004.
  1. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    well, finally started the motor swap today and find out i have no rear engine bracket. i get one and find out that the bracket will not line up to the s1 tranny and the ls motor. is there a different bracket i schould use? im using hasport mounts.
  2. brian11to1
    brian11to1 Senior Member
    did you get it from a 90-93 Integra?
    you are talkin about the rear engine bracket arent ya?
  3. erebunicrx
    Bristol ct
  4. brian11to1
    what car are we speakin about... if its an ED8/9 then you obviouslt arent doing somethig right.
    are you 100% sure the bracket came from a 90-93 INTEGRA?
  5. erebunicrx
    Bristol ct
    the guy i got the bracket from said it was from a teg. are the years different for the brackets? its not a ls tranny but that schould not be a problem right? and yeah its a 91 crx si
  6. brian11to1
    not an LS tranny, what is the trans from? This wouldnt matter as long as it a B series transmission.
    Well either way it wouldnt matter - obviously you've been lied to. You need to look for another bracket... this time make sure its from a 90-93 INTEGRA.
  7. erebunicrx
    Bristol ct
    humm, he gave it to me and its real close just like a 1/2 in off, but enough to not get the bolt in the top hole.
  8. brian11to1
    what did you tell him when you went to get it
  9. erebunicrx
    Bristol ct
    i did'nt tell him anything i called someone and he called someone and showed up with a bracket. i told the first guy i needed a integra rear engine bracket. is there any other motors with a rear bracket close to the same?
  10. brian11to1
    listen to me you need the bracket from a 90-93 INTEGRA. I dont think the bracket of a 94+ integra will work. so call a junk yard and find the damn bracket it shouldnt cost more than $50. I in fact sold Ian (gsrcrxsi) one for $35. So there ya go, theres the answer to your quesiton.
  11. erebunicrx
    Bristol ct
  12. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
  13. brian11to1
