Quoted post[/post]]
Quoted post[/post]]
Well, would a general higher temperature than ambient help increase atomization?
It's a good question and concept.
From what i've read, 450F is the needed temp to vaporize gasoline, i guess part of the problem is the heat required.
I read it would take 2 gallons of gasoline (in a gasoline application) to produce the energy needed to produce 450F, and then you would be able to get 40-60miles until it needed to be re-heated.
I'm sure this can be argued, and I'm stating what i read, not what i think. It kinda seems like a perpetual motion concept they are trying to stress.
I saw some diagrams and blueprints of different designs for atomizers/vaporizers, and i guess it's true that it does help to heat it up.
My car runs between 100 and 175F depending on conditions, with that in mind, my gas is often over 100F sitting in the Az sun... and there's no miracle gas mileage going on there.
I did find out that adding acetone to your gasoline will increase gas mileage up to 30% and can increase power as well.
The hondas noted were at:
2ounces of Acetone for 10 gallons of gas in a civic=20% better gas mileage
1ounce of Acetone for 10 gallons of gas in a pilot went from 20 to 25 mpg and so on...
I guess too much will decrease power/mileage,but it's not shown to cause any harm.
How does this relate?
Apparently, Acetone will help increase the speed ((and)decrease the energy needed) of atomization for gasoline.
This idea would work well on hondas i think, you could build something small that would bolt onto the fuel rail in between the filter and the rail to vaporize gasoline and return the leftovers to the line that already runs from the rail.
Other than exploding, i'm not worried about trying some stuff when i get back to phoenix?
There is a lot going on in this thread. Yikes. Okay, having been through hours and hours of class time dealing with thermodynamics and aeropropulsion systems, I can pass on a bit of info that might help you understand a little better.
1) You don't want to vaporize the fuel in the lines. The system is designed for liquid, not gaseous state fuels. If you wanted to use a gaseous fuel, then their ARE conversion kits out there to run your car on propane. It's not rocket science, you just have to have the right equipment for the job. The injectors that are in the car are designed for liquid, along with most of the other parts. Not only that, you are going to have various mixtures of gas and liquid in a heterogeneous mess not good for consistent flow properties within the system. If you have a system designed to completely change the state of the system, then fine, you are back to getting the right parts to do the job. Just random trivia, but the space shuttle main engines run the fuel through the bell nozzle before injecting it into the combustion chamber, in order to heat up the fuel and to remove heat from the nozzle walls. It is a completely liquid system, btw. I hope this clears up the vaporization issue. But good thoughts.
2) Heating up the fuel helps, but for different reasons than you are getting at. If you heat the fuel up to a certain temperature, the combustion process has to waste that much less energy within the combustion chamber. A similar tactic is used in industrial turbine generators. Exhaust gases being expelled through the turbine side of the generator are routed through a heat exchanger through which incoming air is heated up before combustion. It's called a 'reheat' breyton cycle, I believe. It just raises the internal energy of the fuel/air before combustion, and puts the mix into the combustion chamber at a higher energy state. You wouldn't want to heat up the air in the engine beyond the normal operating temp, because then you are lowering the density of your oxidizer (air), and getting less into the engine. This, however may help with the gas mileage, depends though. Raising the fuel temperature, however, will give you an advantage to a certain extent, in that you are raising the internal energy of the fuel a good bit without decreasing its density, because it is a liquid, and less susceptible to density change pre-vaporization. Another reason not to want to vaporize your fuel in the lines.
3)Acetone, as far as I know, is not anything more than an octane booster; same with toluene. If you familiar with gasoline chemistry and how it works, you know that gasoline is a long chain of hydrocarbons. Basically, the lower the octane rating of the gasoline, the longer the H-C chain is. That means that for every mass quantity of gasoline that is available for an oxidizer (air, n2o, etc.) to react with, there are less reactions that are able to take place the lower the octane number. To maybe explain this better, think of the hydrocarbon chain as a long table with chairs around it, and the oxygen molecules have to sit down in these chairs inorder to react. Well, as you shorten the tables (i.e. raising the octane), there are more spots available at the end of the tables as they are broken up for oxygen to sit down at, thus more reactions per mass of fuel. I'm laughing as I write this, thinking of how ridiculous it must be to read this. So, when you add acetone to the gas, depending on how much you put in it, it raises the octane of the mixture, thus allowing for more power per mass quantity of gas. This will cause two things to happen. 1) you'll make the same amount of bang with less fuel, and will probably drive at a slightly lower throttle setting as a result, increasing fuel mileage. 2) Your o2 sensor will most likely see a richening of the fuel/air mix coming out the tailpipe as a result of the more o2 being able to react completely with less amounts of fuel, and so will most likely lean out the fuel while the engine is operating in closed loop, thus getting better gas mileage. Of course, you can only add so much octane booster before its benefits begin to flatten out at a peak.
I am sure this is the longest post of the night, but this is an informational forum, and genuine questions need answers, some answers not always able to be given in two or three sentences. THis is my take on what you guys are talking about, hope it's bee helpful.
Mike
Edit: Oh, and atomization is only really going to be affected by the injector's nozzle fineness, the distance the injector is from the port (needs time to fully mix with the air), and the aerodynamic quality of the flow in the manifold. The temp of the gas may allow the gas droplets to more effectively separate, but that is something I haven't really studied up on yet. If you want a good lesson in combustion, look up a book by a guy named LeFabvre. It's a jet engine combustion text, but it addresses a good bit of what you guys are talking about.
