more on the cr-z
Discussion in 'Auto Multi-Media' started by Ethan, Jan 18, 2010.
  1. Ethan
    Ethan Well-Known Member
  2. Ethan
    back to the 1.5l engine... lmao
    i guess when it comes out ill work on owning the first cr-z turbo.
  3. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    It's a Hybrid.
    Don't waste your time.
  4. Ethan
    ...! go away!
  5. klyph
    klyph Dismember VIP
    North Pole, AK
    Actually, I bet if you didn't mind going at it with a sawzall and removing a lot of crash safety items, you could make it into a worthwhile vehicle.
  6. Ethan
    that is one car i honestly would give a shit about the warranty. id go right to treating it like a old crx. rip it apart and build it up!
  7. klyph
    klyph Dismember VIP
    North Pole, AK
    So, you WOULD give a shit, by ripping it apart?
  8. Ethan
    wouldn't*
    BLEEPING TYPO!
  9. Magana559
    Magana559 The Warden
    fresno Ca
    wonder how much it will go for??
  10. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    What block is the motor? :ph34r:
  11. GlassHeadlights
    Calgary, AB
    Next year they should come out with a CR-Z Si with a K20...or a new K22 with good torque. :)
  12. honda4life23
    honda4life23 New Member
    aint that suppost to be the new crx
  13. 99sidude
    Ohio
    It's an L15. Same as the current Fit. Rip the battery pack and IMA out and it will weigh 50lb less than a fit... Not quite eg hatch weight, but it will be safe and have a nice interior. Just remember that the crx was offered with several engine choices. There's no reason that this can't down the road.
  14. GlassHeadlights
    Calgary, AB
    Like a Si version with a K would be nice. Fuck hybrid, Americans/Canadians don't want that! We like our high-reving, gas sipping 4 bangers!
  15. Battle Pope
    Sales figures disagree with you.
  16. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    Im sure some high end shop will get that honor before they even hit the streets for extra marketing. And F a turbo 1.5, I'd be the first to swap in an rear engine rear wheel drive LS3 if it wasnt so damn ugly. Now that'd be doing something.
  17. GlassHeadlights
    Calgary, AB
    It's still possible to make a different "trim" that's not hybrid.
  18. Matts96HB
    Matts96HB . Moderator VIP
    possible, but far from likely
  19. 95b16coupe
    95b16coupe New Member
    ct
    read, re-read, then re-re-read 99sidude's post. :ph34r:
  20. DESPAIN
    flower mound TX
    I am going to get for my commute too work
