well i finaly got some pins from the junkyard and put everything together but now my VTEC won't disengage. As soon as i press on the gas a little i can hear it engage and the engine RPMs drop and come back up repeatedly until i let go of the gas. I've triple checked my wiring and it's all good. Does anyone know for sure what signals i'm suppose to be getting from which parts at which times? Such as, i'm getting a ground from the VTEC pres sw at idle and the sw contacts are closed. I unpined the pres sw wire from the ECU plug with the same results. Also i have constant power going to the VTEC solenoid so whenever i disconnect it, the VTEC shuts off. Could i have a bad ECU or would there be another culprit?
The CEL is on also with the VTEC code 21.
