Battle Pope
Well-Known Member
For some reason, Win7 (running the release candidate, 32bit) doesn't like my motherboard. It's an MSI K9N Neo V3, nForce 560 chipset. Motherboard works fine, but occasionally when a program hangs and I have to force a reboot, the board will just "forget" it has a SATA controller till I power down and it detects it again on POST. I am running 2 hard drives and my optical drive from the onboard controller - which brings me to my other problem. Win7 won't access my optical drive. It's an LG dvdrw. Unlike the motherboard I have been able to verify (through MS's compatibility site) that the drive is supposed to work with win7. I assume it's a problem between windows and the sata controller.
None of these issues happen at all, or have ever happened on XP Pro SP3.
Could this just be because I'm using the RC version? I am planning on upgrading out of this motherboard but since I'm still unemployed it won't be anytime soon, so I want to make the best of it - and rebooting into XP to burn CDs or make backups is super dumb.
Full config:
MSI K9N Neo V3
Athlon64X2 3ghz
2gb ram (also needs upgraded)
Nvidia GTX295 (self-contained SLI)
Corsair 750watt psu
1x IDE, 2x sata hdds
sata dvdrw
Full config:
MSI K9N Neo V3
Athlon64X2 3ghz
Corsair 750watt psu
sata dvdrw
