Motor Mount question?
Discussion in 'Civic and CRX - EF' started by big4, Jun 16, 2008.
  1. big4
    big4 New Member
    I just got a 90 SI Hatch with a B18A1 in it. I noticed that the back motor mount is broke off at the beam. How many mount should I be using for this engine swap? It only has three(left/right/rear). Stock EFs have four right?. The rear one is toast..see pic!
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you only need 3...stock ef's have 4 but you will not be able to use the front..
    did the bolts break that were holding the mount to the rear crossmember?
  3. TurboMirage
    its too blurry for me to understand what im looking at.
  4. big4
    big4 New Member
    The cross beam is broke and the mount is still attached to the motor. I'll take better pics in a minute... Thanks guys for your reply.
  5. big4
    big4 New Member
    Is this common in B18A1 swaps?
  6. big4
    big4 New Member
    someone before me did try to weld it...from the looks of it.
  7. TurboMirage
    wow... i'd cut all of that out and weld in new thicker metal.
  8. big4
    big4 New Member
    Is this a common problem?
  9. efhondakid
    Akron-Canton, Ohio
    Ive never seen that before, it looks like the stock rear mount welded to the rear crossmember, far from being the right way to do it.
  10. big4
    big4 New Member
    Someone did try welding it before me owning it(looks that way). The rear mount is factory the r/L are aftermarket....all are ripped. I'm going all solid mounts. I got my work cut out for me......lol
  11. big4
    big4 New Member
  12. efhondakid
    Akron-Canton, Ohio
    Nope that is the front one. I have a rear crossmember that I will give you if you come and pick it up/pay to ship it. Im in Uniontown OH.
  13. big4
    big4 New Member
    Yeah I realized after I posted that it was the front one. Man I wish money grow on trees. PM sent...thanks bro.
  14. big4
    big4 New Member
    I sold this headache. paid 200 sold it for 450. Thanks for all your help.
