i Have a 98 honda civic. i want to put an OBD2 H22a motor in it. ok the motor mounts. do i need to complete kit or just the rear transmission mount and driver side mount?? Any help would be great!!
How hard would it be to wire up an OBD1 ECU to an OBD2 ECU?
You will need the complete motor mount kit. You can go with hcp,place racing, and HAsport. HAsport cost more but most people prefer it to the others. You will need to use a jumper for the ecu.
yeah i got a 97 civic w/98 h22a4, i got place racing mounts but don't like the way the mototr sits; not enough clearence in between the motor an driver side shock mount. mabye a width big enough to stick two nickels.
j i plan on redoing it later this year with hasport. just my opinion. also you can wire the obd2 motor into your car harness and just get a skunk2 conversion harness for a civic or run a obd2 gsr ecu.
