Motor Mounts
evcivic
iam installing a ls vtec on my 98 hatch. which motor mount will i have to go buy in the dealer. :(
the ones that are for the motor are probably your best bet but i think you can use any B-series mounts. watch out on the rear mount cuz i think it's application specific. if you want to go aftermarket look into HASport or Place Racing mounts. HASport should be your first choice out of the 2. i think HCP makes some mounts also.
christ how many times are people going to ask the same questions? rear trans mount 99-00 civic SI, bracket that mounts between the upper drivers side mount and the block from a 99-00 SI. use your stock civic upper drivers side mount. I used civic mounts for all the rest but most of the integra ones are interchangeable.
