motor mounts
5thgenerationc
ok i just got my old motor out of my 94 civic and i am putting in a b16 jdm sir2 motor i just got from hmo.my question is what driver side mount do i need to get to fit the motor and my car i read the swap form and it says use the mounts that come with the motor but i did not get the mounts with the motor if anyone knows what mount i need to get it will be a big help
thanks :worthy:
you need to score a 94+ teg rear mount.
the d-series MIGHT work on the rear one.. im not sure though...
yeah, i just bought the rear mount off of a 99-00 si and it fits perfect.the only one i need is the driverside im stuck on this one and dont know what one to get.i also tried to get the mount from the si and it had a different set up and would not fit
thanks
Are the bolts on the drivers side off set or straight.
