Motor mounts
poncho67
I'm swaping in a d16z6 into my 91 civic and im wondering which mounts should i use. I don't really want to pay($269) for billet mounts:eek: is there an other option that is more cost effective? Thank for any input
you most certainly can. although be aware that with inserts the passenger cabin is going to be absorbing a LOT more of the engines vibrations. for the mounts just switch over your old engines post mount (part that bolts to the block) to the z6. then you can use stock mounts everywhere else. this is assuming you are retaining a cable clutch. if not, then you would need a different trans mount.
You can use stock mounts with insert but it is less comfortable for daily ride than inno or has. Yeah, I know these are expensive. :(
