Motor oil burning
Discussion in 'General Tech and Maintenance' started by b18delsol, Jun 17, 2004.
  1. b18delsol
    b18delsol Member
    Well here is my problem, I have to add like a half quart of motor oil every 3 days or around 300 miles. smoke comes out of my exhaust everytime i step on the gas. I check the engine and there is no leak so it is coming straight out of the exhaust. I use mobil1 5w30 and my motor is a usdm B18c5 swap in a del sol. The motor has about 70,000 miles. People say that i have bad pistons? anyone know what might be the problem.
  2. JDM4LYF
    JDM4LYF Junior Member
    Could be your valve seals. id gettem checked out.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
  4. 97CTR
    97CTR Senior Member
  5. projectxspeed
    projectxspeed Senior Member
    New Hampshire
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    me too, do a compression test or even better a leak down test.
  7. b18delsol
    b18delsol Member
    if the ring is bad kan i be losing torque or horsepower from dat?
  8. phunky.buddha
    Dallas / Fort Worth, TX
    if da ring is bad yez yoo kan lo0ze h0zpowah an toq frum dat
