motor stutters
Discussion in 'General Tech and Maintenance' started by SiR_Redneck, May 22, 2005.
  1. SiR_Redneck
    SiR_Redneck Member
    only when i take off form lets say a light, it will shutter/stutter a bit then it will catch itself and start goin, no problems after its moving, and it will do it also when im turning and when im on the gas a bit, what sensor, if not a sensor waht could be doin this
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Sounds like an ignition problem... check your plugs, wires, distributor, cap, rotor etc.
  3. B16CRX
    B16CRX Senior Member
    Greenville, SC
    Definitely a ignition problem from teh sounds of it. I would go ahead and do a tuneup if I were you. That should fix it.
  4. APACHE
    APACHE Junior Member
    ATLANTA, GA
    If not, then it's ur Disturbtor.....
  5. SiR_Redneck
    SiR_Redneck Member
    hey thanks guys it seems to be fixed now, i changed the plugs, but i still have the one problem of a CEL 43, i know its the Fuel Sapply code, but i cant figur out what sersor or sensors would throw this code. anyone know?
