Motor Swap
Discussion in 'HYBRID -> EG-EK / DC' started by smokeshowmo2, Jan 7, 2003.
  1. smokeshowmo2
    smokeshowmo2 Junior Member
    i want to buy a 5th generation civic hatchbackbut i want to do a motor swap. i want to do an ls swap because it is cheaper.do i have to change the ecu if i do that swap or is the old ecu good to use. any help much thanks.
    thank you
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    you'll want a new ECU.
  3. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    most of the time you'll get the ecu with the swap.... and i wouldn't recomend using a stock ecu.... exp the p28
  4. smokeshowmo2
    what are the different ecu's like p28 and what does it mean. and what is teh best tranny to go with.
    thanks
  5. B16
    B16 Super Moderator VIP
    yay area, CA
    use the LS tranny, P28 is the civic EX ecu, easily modified and many programmed chips circulating out there for it.
  6. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    well, with LS u can run the Si ecu, i am b/c i havent had time to swap it out yet. its still a powerful engine with the wrong ecu, but it will b alot stronger with the better ecu. use B16a1 tranny it has best gearing.
  7. prawjEKt Cx
    upstate NY
    sorry, i don't know why i suggested a p28 in the first place...i tend to skim through shit and just answer when it looks like the same question as the rest of them, ok now listen, if your gonna run a ls in a 5th gen get a 94-95 ls ecu (not sure of the exact code, just check in the references section on this site)
  8. pissedoffsol
  9. onefastcivic
    onefastcivic Senior Member
    ok this is the ecu you want to find. and yes i mean find. get the p30 from the 94 ecu from a delsol dohc that is your best bet but you will have to search for it :blink: :spin:
  10. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Damn man pass that shit over here,I need a hit.Why would he use a vtec ecu from a b16a3 on a nonvtec ls motor?And what are you talking about find one,They came in cars for several years in many countries.
  11. 2 litre EG
    2 litre EG Senior Member
    so cali
    i say run with the LS ECU... cause why would you want a VTEC ECU in a non-VTEC car??
    92b16vx: puff puff give mayan, puff puff give!!! :lol: :lol: :lol:
