motor swapz
Discussion in 'HYBRID -> BA-BB /CA-CD' started by H22Adelsol94, Aug 1, 2003.
  1. H22Adelsol94
    H22Adelsol94 Junior Member
    I have a 1986 honda preluse si. I was aondering if there is any motor swaos i can do to it.
  2. 90 accord
    90 accord Chicks dig the box Moderator VIP
    Mesa, AZ
    wait, your name is h22adelsol, but you drive an 86 prelude?
    you can do any swaps you ever want really. its all a matter of how much you want to spend.
    h22 is the most commpn swaps into preludes and accords alike, but i don't think it will drop straight in.
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    :werd:
    I think it would cost as much for a swap like that as it would to just buy a slightly newer prelude. Your options are probably pretty limited for cost efficient swaps.
  4. racerx h23
    racerx h23 Member
    TN
    Look at the A series that came in the 86- 89 Accords. One of those would probly be your best bet for a good bang for the buck swap. Just be sure you overhaul the engine.
  5. spiffyguido
    spiffyguido Junior Member
    Alberta, Canada
    Don't forget the option of swapping in a JDM B20A. Then at least you would have a DOHC engine. It drops right in, no changes needed.
  6. racerx h23
    racerx h23 Member
    TN
    Will the stock 2g mounts work with the b20a???
  7. lilvtec
    lilvtec Junior Member
