avsrightwinger19
Okay, i hate to bug you guys...but maybe someone here can help me out. So i bought a 91 civic si with a b16a obd0 swap. The idle hops up and down after a cold start up, it seems to not be operating at its best(performance wise), it failed emmissions, and vtec won't engage. The ecu was giving me a MAP sensor code so i replaced it because the car had all the symptoms of a faulty MAP sensor. The error code went away but it seems to run identically. Now the ECU is flashing 3 things; VTEC solenoid valve, knock sensor, and secondary o2 sensor. I noticed that if its giving you a code 2 (faulty secondary o2 sensor) it might be because of a faulty ecu, but i really don't think thats the problem. If anyone has had any similar experiences or suggestions of what the problem could be, i would greatly appreciate it.
